2003 Buick Regal Shift from Park to Reverse or drive
2003 BUICK REGAL
84,540 MILES • 6 CYL • FWD • AUTOMATIC
SCOTTJ1966
The transmission will not shift into another gear intermittently. It was in an accident and was repaired at a dealership. I drove it for a week. This morning it wouldnot shift out of park. I had the brake engaged ( I have the car for 3 years now). Please advise....Help!!
Feb 8, 2010 at 4:16 AM
HMAC300
  • 48,601 POSTS
this could be a couple of things. As it was in an accident it could be a broken trans mount 1 or more. Or morelikely the cable that shifts the transmission has broken and won't move the car out of gear. If the shifter moves especially. the easiest way to check this is have someone turn the key on and depress the brake. then have the hood open and look on the driver's side. there is a lever that should move forward and backward. when the other person moves the shifter into drive see if hte lever moves or if the cable is moving in it's housing. If all that does work then you may have a transmission problem. Also there is a switch that lets you shift the shifter and that may not be getting electricity letting itwork......
Feb 12, 2010 at 9:18 AM
