2003 Buick Regal Runs hot
2003 BUICK REGAL
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
MATHEW1323
Ok my problem is that i have my buick regal and it freaking heats up after i have flushed and cleaned my radiator, changed thermostat, water pump and release the air from the thermostat that builds pressure within the cooling system. It's fine until i hit a red light that makes me wait for a long time, it'll go above the normal level and will go up to 3/4. i think that is too much it should be at 1/4 or at the most half way..is there a solution to these. Any reccomendations? let me know please thanks.
Apr 19, 2009 at 9:13 AM
  • 110,244 POSTS
Is the cooling fan working. If not that is why it is overheating when you sit still. Does it overheat when driving?
May 3, 2009 at 9:39 AM
