2003 Buick Regal I think its the ECM?
85,000 MILES • 6 CYL • FWD • AUTOMATIC
WOOD_DUSTY_2004
My car wont start and the key is stuck in the ignition. The gages andlights are going crazy. The lights are flickering and the gages are going back and forth. Is this the ECM, and what can I do?
Nov 13, 2009 at 10:27 AM
  • 110,248 POSTS
If the engine refuses to start and the gauges are going crazy, it could be a couple things. I would start by having the body control module (BCM) tested to make sure it is okay. ALso, just for the heck of it, check for ground problems. Make sure the one to the engine block is clean and tight, the battery terminals are clean and tight, and check for body grounds that are loose, rusted, or broken.
Let me know what you find.
Nov 24, 2009 at 12:25 AM
