2003 Buick Regal
174,512 MILES • 6 CYL • 2WD • AUTOMATIC
TIMBRIDGEMAN
WHEN PULLING OFF THE CAR SLOW TO PICK UP SPEED
IF I PUSH DOWN HARDER ON THE EXSERATOR IT START TO JURK
WHAT COULD BE CAUSING THIS PREFROMENCE
Jun 11, 2010 at 8:07 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 11, 2010 at 11:33 AM
