2003 Buick Regal
LESSIE.HANDY
  • 5 POSTS
Air Conditioning problem
2003 Buick Regal 6 cyl Front Wheel Drive Automatic
what do I do when all of this has been done. The air conditioner works just don't work normally. I'm told this has already been done.
Mar 8, 2010 at 6:12 AM
  • 110,248 POSTS
What work was done?
Mar 12, 2010 at 12:09 AM
LESSIE.HANDY
  • 5 POSTS
The refrigerent presssure sensor switch, the clutch relay control head (havc) coolant fan relay and a compressor. All of this has been relpaced. Still don't cool air. The computer says the unit is working. The scanner is showing air condition is requested and the light on the instrument panes says the ac is avtivated. His name is Buddie Walton at 817-738-2363, he can tell you more. All I know is that in order for me to get air, I must ride around with "Service Engine Soon" on all while I run my ac. To turn this light out I won't have any ac. Thank you for your time and effort in helping me try and figure out this complicated problem. It is truly a blessing in diguise that I found you all. I will refer you to others.
Mar 12, 2010 at 2:22 AM
