2002 Buick Regal Sun visor
47,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPUHLER55
I am trying to replace the driver side sun visor and can't get the plastic cover on the mounting bracket off. Does it take a special tool? I'm assuming there are mounting screws under the plastic cover holding the visor to the roof. Any help would be appreciated.
Feb 13, 2009 at 7:45 AM
GFIMOTORCARS
  • 673 POSTS
What you will need is a small thin screw driver or thin plastic wedge. Get it under the side of the plastic cover. Pry back and it should pop off. These are sometimes tight to get off but once off will give you access to the removal screws.
Feb 13, 2009 at 10:11 AM
