2002 Buick Regal starting problem
BJSTOUT
  • 5 POSTS
Engine Performance problem
2002 Buick Regal 6 cyl Front Wheel Drive Automatic
just installed IAC Valve ran for a day & half went to start and will not start, tested, fuel only at 50% is
the fuel pump bad?
Jun 17, 2009 at 2:31 AM
  • 75,988 POSTS
fuel only at 50% is the fuel pump bad?
What is the fuel pressure reading?
Jun 17, 2009 at 2:35 AM
BJSTOUT
  • 5 POSTS
at 48% now
Jun 17, 2009 at 2:50 AM
BJSTOUT
  • 5 POSTS
FUEL IS 48 PSI RIGHT NOW
Jun 17, 2009 at 2:54 AM
  • 75,988 POSTS
Your fuel pressure is low-if its a 3.8L engine
K and 1 is the 8 digit of the VIN no.s, which VIN??
VIN K 53-59psi
VIN 1 48-54psi
Jun 17, 2009 at 10:00 AM
BJSTOUT
  • 5 POSTS
installed new IAC VALVE 2002 buick regal ran for a while then will only run with foot on gas pedal let up on pedal and dies out. Installed new fuel pump got started ran rough but doing the same thing as when changed the IAC Valve can't get to stay running. Like something is wrong with the idle.
Jun 19, 2009 at 6:23 AM
  • 75,988 POSTS
Did you clean out the IACV passages ? also might want to clean out the EGR valve and see what happens.
Jun 19, 2009 at 9:48 AM
BJSTOUT
  • 5 POSTS
Got it fixed.....was the fuel pump all along removed the new IAC Valve and it was stuck open.
Thanx for your time.
Have a good weekend.
Bev
Jun 19, 2009 at 9:51 AM
