2002 Buick Regal spark plugs
WAYNE PASSERO
  • 2002 BUICK REGAL
Engine Performance problem
2002 Buick Regal 6 cyl Front Wheel Drive 100, 00 miles
procedure for replacing rear plugs
Tuesday, March 16th, 2010 AT 11:08 AM
  • 109,885 POSTS
There isn't a procedure persay. They are tough. To get them from the top is almost impossible. When I do them, I access them from under the vehicle. If you have access to a lift, that is the easiest way. If not, safely lift and secure the front of the car as best you can. From that point, you need to get under the car and R&R them.
Tuesday, March 16th, 2010 AT 1:25 PM
