2002 Buick Regal po0171 code
GENEIMLER
Engine Performance problem
2002 Buick Regal 6 cyl Front Wheel Drive Automatic
replaced cat and now i get this code. replaced o2 sensor on back side of manifold still get the code. i had replaced the mass air sensor last month from a different problem. no vacuum leaks found.
Sep 17, 2010 at 1:33 AM
WRENCHTECH
  • 20,760 POSTS
That is a lean code that means there is too much unmetered air getting into the engine. This could be a vacuum leak or a problem with the MAF sensor.
Sep 17, 2010 at 2:12 AM
