2002 Buick Regal electric glitch
80,000 MILES • 6 CYL • FWD • AUTOMATIC
TOM F.
Once in a while when I start the engine, the heater fan, rear window defroster, air conditioner, and cruise control, won't work.
All other elec equipment works fine. Then after a few minutes, it all come back on and works normal.
I suspect a relay but, haven't been able to associate all the problem electrical devices to one relay.
I have had some luck, restarting the car a few times, and this sometimes brings back the non working items.
what do you think is wrong?
Apr 24, 2009 at 4:10 PM
BUDDYCRAIGG
  • 2,262 POSTS
those 3 items all get their power from an orange wire coming out of the ignition switch.
a red wire goes into the switch and branches off in two circuits, a brown wire and a orange wire.
next time it happens, try your wipers (which is on the brown wire) it they work, then i suspect the ignition switch is the problem.
Apr 26, 2009 at 10:00 AM
