2002 Buick Regal car not starting
144,000 MILES • 6 CYL • 4WD • MANUAL
TPROTHRO
Battery and alternator is good. I turn the key to start, it acts like its about to start but doesn't
Aug 5, 2010 at 3:53 PM
  • 75,988 POSTS
Do below to determine if its compression, fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Aug 5, 2010 at 8:01 PM
