2002 Buick Regal Buick Regal 2002 odometer, PRND, Trip dark
68,000 MILES • 6 CYL • FWD • AUTOMATIC
VENTSUE
  • 8 POSTS
The odometer, PRND indicator, & trip meter are dark. It started as an intermittent blacking out.
What is the likely cause of this problem, & how can it be repaired?. From what I've learned it sounds like the circuit board in the cluster needs repair. I talked with a person at a local GMC dealer service dept., & he said it might just need reprogramming. Is that likely? It will cost $95 to find out. If the repair of the cluster must be done the labor will be $147, the circuit board repair $384. The unit will be sent out of state for repair.
Sep 22, 2010 at 3:44 PM
BMRFIXIT
  • 19,053 POSTS
Cluster is most likely the issue
reprogramming it may or may not work
i would give it 25% to work at best
use a scanner tool and check the cluster select data
check IPC data and BCM data
Many places on line sell an after market cluster that should work just fine for you
Sep 23, 2010 at 11:06 PM
VENTSUE
  • 8 POSTS
I understand that having the original repaired/reinstalled saves the mileage data. If I have an after market cluster installed would it need programing to show the original mileage?
Sep 24, 2010 at 5:51 AM
BMRFIXIT
  • 19,053 POSTS
Usually you have to supply them with the VIN and correct milage and they ship it plug and play
Sep 24, 2010 at 9:57 AM
VENTSUE
  • 8 POSTS
That is a problem, as I can't read the mileage.
Sep 24, 2010 at 6:13 PM
BMRFIXIT
  • 19,053 POSTS
Check your PM
and let me know
i had just sent you a message
Sep 24, 2010 at 11:28 PM
VENTSUE
  • 8 POSTS
How do I check PM? When I clicked on the icon it said I couldn't send PM until I had posted 10 times.
Sep 25, 2010 at 1:13 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_mes_1.jpg
you should have a private message from me if not let me know and i will email it to you to check your private messages: at top of this page check if have any new messages click it ,
Sep 25, 2010 at 3:18 PM
VENTSUE
  • 8 POSTS
Thanks for the really informative link, BMRFIXIT. I am going to check with my independent mechanic to see if he will take on this job.
Sep 26, 2010 at 7:14 AM
BMRFIXIT
  • 19,053 POSTS
good luck and let me know if it works you
Sep 26, 2010 at 12:18 PM
