2001 Regal Cat. Converter V-6 automatic Trans.
JBLAKESLEE
A friend recently had the Cat. Converter replaced. A aftermarket one was used. Now the check engine light stays on all the time. He has tried clearing all the codes. The vehicle has 104 thousand miles on it.
A GM dealer told him that if a aftermarket Cat. is used this sometimes happens, and there is nothing that can be done about it.
Any truth to this?
Thanks for you help
Nov 9, 2007 at 1:40 AM
DOCHAGERTY
  • 9,606 POSTS
that depends on the cat. if it was a direct replacement cat, probably not. if this was a one size fits all type cat or a non OEM type, then yes, it will command the SES lamp on.
Nov 9, 2007 at 5:16 PM
JBLAKESLEE
[quote:9cfee3f490="Dr. Hagerty"]that depends on the cat. if it was a direct replacement cat, probably not. if this was a one size fits all type cat or a non OEM type, then yes, it will command the SES lamp on.[/quote:9cfee3f490]
Is there any way to reset it...
Nov 9, 2007 at 9:54 PM
