2001 Buick Regal Repair hints for 201 Buick Regal LS
BABE3671
Engine Performance problem
2001 Buick Regal 6 cyl Front Wheel Drive Automatic
Check engine light came on after the fuel filter was replaced. The vehicle doesn't have any power until 2000 RPM and then it will kick into speed.I would like to know if the vehicle comes equipped with an on board diagnostic unit.
Jul 6, 2008 at 3:09 PM
BMRFIXIT
  • 19,053 POSTS
OBDII connector on the driver side
u need a scanner to check for codes
autozone and most local shop can help you reading the codes
Jul 6, 2008 at 10:54 PM
