2001 Buick Regal It won't start some times, not at all now
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
TONY G
In the last year, maybe 7 or 8 times the car wouldn't start after you drove it a little and shut it off. The battery is fine, it doesn't even try to turn over, click or any thing, the gauges all go dead while you try it. Usually after setting for 3 or 5 minutes, I also move the shifter back and forth, and keep trying it, it will start. Tonight it wouldn't start after setting all day. It seems the key is not shutting off all the way, but I can pull the key out, and can pull it out with it on also. i jumped the solenoid, and the starter cranks. how does the shifter position tie in to the ignition switch?? Any ideas? Thanks, I will donate if you do help me. Thanks, Tony
Jan 25, 2008 at 1:59 PM
BMRFIXIT
  • 19,053 POSTS
[quote:53420bd85e="Tony G"]Other Category problem
2001 Buick Regal 6 cyl Two Wheel Drive Automatic 170000 miles
In the last year, maybe 7 or 8 times the car wouldn't start after you drove it a little and shut it off. The battery is fine, it doesn't even try to turn over, click or any thing, the gauges all go dead while you try it. Usually after setting for 3 or 5 minutes, I also move the shifter back and forth, and keep trying it, it will start. Tonight it wouldn't start after setting all day. It seems the key is not shutting off all the way, but I can pull the key out, and can pull it out with it on also. i jumped the solenoid, and the starter cranks. how does the shifter position tie in to the ignition switch?? Any ideas? Thanks, I will donate if you do help me. Thanks, Tony[/quote:53420bd85e]
you may need a new ignition switch
steering connected throw a cable at the back of the switch
Jan 27, 2008 at 12:25 PM
