2001 Buick Regal Dashboard/Heat/AC Controls
103,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHESAFIXER
Six months ago my dashboard lights would only stay lite sporadically and now recently my heat/ac and cruise control is the same (they all work sporadically). What could be the problem and is it costly to fix? Thanks for your help!
Sep 29, 2008 at 8:31 AM
TRAINBALL
I have a 2004 regal and have the same problem. Have you figured it out? iif so ,could you email what it was ? scoulter31@msn.com
Oct 2, 2008 at 12:52 PM
TRACYKAT
I am having a very similar problem with my 2002 Buick Regal--no speedometer, gas gauge, all warning lights on, no per windows, a/c or heat and no radio. Were you able to repair yours? Any input would be greatly appreciated
Thank you!
Jun 14, 2017 at 4:13 AM
HMAC300
  • 48,601 POSTS
it may be the dash going bad as they are digital and can be rebuilt to verify cruise light check B10 on back of cluster for power when cruise is on if it's getting power then it's either the info center which you can try a reset or a dash problem you can also check ground on steering column behind dash .
Jun 14, 2017 at 5:27 AM
