2001 Buick Regal DASH DISPLAY
BCMONROE
Electrical problem
2001 Buick Regal 6 cyl Front Wheel Drive Manual 41.000 miles
2001 BUICK REGAL LOW MILES...V-6 38 A/T PROBLEM - THE LED DISPLAY IN CENTER LOWER OF CLUSTER WILL NOT DISPLAY ODOMETER OR GEAR SELECT ...THIS IS THE ONLY PORTION OF DASH THAT IS LED! THE DASH WAS PULLED AND REPLACED!..DID NOT SOLVE PROB. ANALOGE GAUGES. HEAD LAMP SW. AND DIMMER ALL FUNCTIONING PROPPERLY CONSOLE SHIFT ,RADIO, HVC LIGHTING , SUN SENSOR NITE SENSOR ALL WITHIN SPECS. A VACUUM FLOURSCENT PROBLEM ???? BCM ? WHERE DOES THIS PORTION OF DISPLAY GET CURRENT.... THANKS BC MONROE
Jan 25, 2008 at 5:11 AM
2CARPRO JACK
  • 11,533 POSTS
Software I have doesnt really show a source for the light power. Might come from the trans position switch.
Jan 25, 2008 at 7:41 AM
BCMONROE
[quote:0077092a57="2CarPro Jack"]Software I have doesnt really show a source for the light power. Might come from the trans position switch.[/quote:0077092a57]......... jack ill get back to you monday we are going to re-scan with gm tech. II CK PRINDALE SW. AND BREAK DOWN BCM MODULE FURTHER...THANKS BCMONROE
Jan 25, 2008 at 8:18 AM
