how to bleed brake system after mastercylinder replacement
May 6, 2010 at 8:33 AM
TOOOMANYTOYS
✓Experienced Mechanic
The easiest way is to bench bleed the master cylinder. Push master cylinder piston in with screw drive and block both passages when relaesing. From there gravity bleed all wheels. Then regular pump bleed to finish.
