2001 Buick Regal
200,000 MILES • 6 CYL • FWD • AUTOMATIC
PETERJHENRY
I need to replace fuel pump. Do I need to drop tank or is there a panel in the trunk to replace it. And what I could problems I could face. Thank you please send to peterhnr3@gmail.com
Oct 13, 2010 at 1:24 AM
JDL
  • 16,098 POSTS
Yes, there should be an access panel. No electrical sparks or anything around gas fumes.
https://images.2carpros.com/forum/automotive_pictures/170934_regal_fuel_pump_1.jpg
Oct 13, 2010 at 1:38 AM
WRENCHTECH
  • 20,760 POSTS
Sorry, we don't send e-mails.
Yes, the tank has to be removed. Your biggest concern is how much fuel is in the tank. This is not really a job that should be attempted without a lift and transmission jack to support the tank.. You are going to have to partially lower it to access the line connections on the top of the tank. This can be a very messy job if not done right.
Oct 13, 2010 at 1:39 AM
