2000 Buick Regal Stalls/Black Smoke
101,000 MILES • 6 CYL • FWD • AUTOMATIC
MATHOM
While driving, car shut off. While trying to restart, it would usually stop again in 0 -3 secs. If it stayed running, the RPM's go up and down, and get black smoke from the exhaust. After sitting for 5 mins, it ran fine. No check engine light or codes yet. From reading other posts, I am planning on checking/doing a general tune up, w/ plugs/wires, fuel/air filter. Any other suggestions?
Sep 19, 2009 at 6:49 AM
  • 75,988 POSTS
Try cleaning out the idle air control valve, check the throttle position sensor and MAP sensor, also clean out the EGR valve-
Black smoke points to rich mixture:
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Sep 19, 2009 at 6:53 AM
