2000 Buick Regal signal lights
120,000 MILES • 6 CYL • FWD • AUTOMATIC
PITTSBIRD2000
I have a 2000 buick regal and the signal lights work sometimes, what is the problem?
Apr 22, 2010 at 3:59 AM
INTERNETMECHANIC
  • 700 POSTS
Front--back, both? Did you check bulbs--bulb sockets, where applicable, wiring connectors? At the rear, the turn and lower brake lites use the the same bulb filament, just, not at the same time. The problem is usually in the multifunction switch, but, if you want to check wiring circuits, we can do that. When the problem is ongoing, did you check applicable fuse/s, voltage on the fuse circuit?
Apr 22, 2010 at 4:39 AM
