2000 Buick Regal Not a car repair person
TREKEEGIRL
Electrical problem
2000 Buick Regal 6 cyl Front Wheel Drive Automatic
I have a problem with my Buick Regal. Whenever I use the turn signal, the indicator on the dashboard is flashes faster than normal, but the turn signal light at the back of the card does not flash at all. The cruise control has also stopped functioning. Can someone tell me what might be causing the problem, and hopefully give me a solution?
Jennifer
Aug 18, 2008 at 10:50 AM
  • 31,937 POSTS
Hi there,
Have the globe on the rear changed as it has blown, the faster flash rate indicates this , as for the cruise system, may be get a scan first to see if there is a problem code set.
Mark (mhpautos)
Aug 18, 2008 at 7:02 PM
