2000 Buick Regal My car shakes
11,000 MILES • 6 CYL • 2WD • AUTOMATIC
QUESTSEEKER17
My car began shaking a tiny bit while driving a month or two ago. I had the tire pressure checked and that didn't do anything. Now it shakes much worse. It is a gentle rocking when going slowly, goes to a very serious shaking in the middle speeds, and a hard vibration at high speeds. I am wondering what it could be so that I can take it to the right place. Thank you!
Aug 27, 2010 at 7:09 AM
LEGITIMATE007
  • 5,121 POSTS
hi, thank you for the donation, the shaking could be several things, a slipped belt in one of the tires, is a good possibility and also bad bearings, may be another, a trained eye will need to check for a slipped belt, and a bad hub/bearings will need an inspection
Aug 27, 2010 at 7:32 AM
