2000 Buick Regal humming or roaring noise
2000 BUICK REGAL
136,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKE OSMENT
My wife's Buick Regal has started a humming or roaring noise as you accelerate above 30 mph. It does not make any noise at idle. It is not a grinding like brakes. It doesn't increase when I turn the wheel. It is just constant while driving at speed. Any thoughts?
Nov 29, 2009 at 7:24 PM
OVIEDOBOB
[quote:274042b5f8="Mike Osment"]Noises problem
2000 Buick Regal 6 cyl Front Wheel Drive Automatic 136000 miles
My wife's Buick Regal has started a humming or roaring noise as you accelerate above 30 mph. It does not make any noise at idle. It is not a grinding like brakes. It doesn't increase when I turn the wheel. It is just constant while driving at speed. Any thoughts?[/quote:274042b5f8]
I have the same problem. Mechanic couldn't find problem. Let me know if you get solution.
Dec 7, 2009 at 12:34 PM
OVIEDOBOB
Same problem with my wife's 2000 Regal. Identical symptoms to yours. Tires checked OK by tire dealer. Local mechanic check everything with car up on rack, says can't pinpoint problem. Not typical symptoms for CV's or drivetrain. I think it is front wheel bearing, so maybe I'll check with another mechanic.
Did it get worse yet? Or did you finally identify problem/fix?
Bob
Dec 7, 2009 at 12:37 PM
BRINSDRACO777
My mom has the same problem.I have a mechanic in the family, he said to drive down the road and pull the wheel back and forth to see if the noise changes in pitch,usually the bad bearing will be on the side the noise gets louder.Still trying to diagnose which one it is.Probably better to replace both at same time though!?
Dec 26, 2009 at 10:00 AM
BRINSDRACO777
Oh yeah ,make sure you know if you have metal or plastic clips on the abs connector before buying parts!!!
Dec 26, 2009 at 10:02 AM
IDENIS
I have the exact same car make a model, and for me it was the bearings on the hub assembly.
Jan 7, 2011 at 9:56 PM
