2000 Buick Regal heat and ac
90,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKE ZANTI
on this 2000 buick the blower motor don't work.I replaced blower motor resister and heater switch unit.I have power to resister and a good ground.Some times I get motor to work on high.When you check fuse the 30 amp fuse high motor dim test light.
Nov 19, 2008 at 12:57 AM
MIKE ZANTI
I found out the problem from another member.
Thanks
Nov 19, 2008 at 1:29 PM
