2000 Buick Regal Heat A/C Blower
61,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHNDINGLE
The heat a/c blower only works sometime. When the blower does not work the rear window defogger and the cruise control also do not work.
Contact have been checked
Oct 30, 2008 at 3:21 PM
  • 110,251 POSTS
Hi:
It sounds like either a ground problem or a problem with the BCM.
Nov 15, 2008 at 5:02 PM
MIKE ZANTI
I had same problem and it was the ignition switch.I found out from another member.
Nov 19, 2008 at 1:22 PM
