Electrical problem
2000 Buick Regal 6 cyl Front Wheel Drive Automatic
THE DAY TIME DRIVING HEAD LITES WENT OUT IVE CHECKED LAMPS FUSES CONNECTION TO BOTH SIDES OF THE LITES ALSO THE HIGH BEAMS ONLY COME ON WHEN I HOLD THE LEVER BACK MANUALLY AND THE SWITCH ON THE DASH WILL ONLY TURN ON THE PARKING LITES FRONT AND REAR I CAN HEAR A CLICK BEHIND THE GLOVE BOX ONLY WHEN THE SWITCH IS BEING PULLED OUT TO TURN ON THE LITES I REMOVED THE THE GLOVE BOX AND FOUND A SERIES OF 4 RELAYS ONE RELAY CLICKS WHEN PULLING OUT THE SWITCH STILL NO HEAD LITES
Jan 12, 2010 at 9:56 AM
