2000 Buick Regal hard steering
KEN ZAWROTNIAK
Steering problem
2000 Buick Regal 6 cyl Front Wheel Drive Automatic
by mistake i put brake flud in power steering box now it steers like a truck. is there a way to drain the system or does every thing encluding the rack and pinion have to be reolaced?
Jul 23, 2009 at 2:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
If you haven't ran the vehicle with the brake fluid in the power steering system for very long than most likely it has not caused any permanent damage. You can drain the system and replace it with the correct GM power steering fluid. Place a drain pan under the rack and pinion and remove the power steering pressure and return lines from the rack assembly to drain the fluid.
Jul 23, 2009 at 6:35 AM
