Fuel gauge going crazy!
BRUNOM
I have a 2000 Buick Regal GSE. When I start the engine, the fuel gauge goes to full and after a moment it drops to empty. I bought all new fuses and replaced the them in the passenger side fuse box. I also wiggled the wires near the fuel tank.
I recently had an O2 sensor replaced by the catylitic converter - hope this helps.
Thanks. R/Matt
Apr 14, 2007 at 8:24 AM
MERLIN2021
  • 17,250 POSTS
Sounds more like a bad sending unit in the tank...or the guage on the dash is bad.
Apr 17, 2007 at 3:48 AM
LSUSSEL
  • 252 POSTS
I have had this same issue on a bonneville, what sometimes happens is the fuel senser, the sensor that measures how much fuel in the tank you have, sometimes it gets corroded. Go to any auto parts store and pick up a bottle of Cheveron Techron, it should be in a black container thats round towards the bottom and a long neck, it costs about 8 bucks and pour it in on a almost empty tank, this should clean up the sensor and even the fuel lines, combustion chamber ect. I have done this many times for customers that dont wish to replace the sending unit as most newer cars, the sending unit, fuel pump and tank are all in one, so if one goes back you need to replace it all, can be costly, so try that chevron techron, how this helps.. let me know!
Apr 20, 2007 at 3:48 PM
JASON ALMONT
The above comment is really horrible information. Techron can’t fix a mechanical issue on a sending unit. The gas tank, pump, and sending unit are all replaceable parts separately. No way you’re a mechanic and telling people these flat out lies.
The most likely culprit is a bad sensing unit.
Sep 7, 2024 at 3:04 AM
  • 55,562 POSTS
Yep, good call, LSUSSEL must work for Chevron lol. Here is how to change it out so they can fix the problem. Luckily there is a trap door, so you don't need to drop the fuel tank. Check out the images (below). Let us know if you need anything else.
Sep 7, 2024 at 3:09 AM
