2000 Buick Regal gasoline
MATTHEW412
Smells problem
2000 Buick Regal 6 cyl Front Wheel Drive Automatic
When I start the car and when I drive my car has a strong smell of gasoline.
Nov 9, 2009 at 2:19 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd check the fuel lines and connectors from front to back, engine compartment ,also. Check around the injectors, pull line off pressure regulator, check for gas. You may have to check evap system. Any codes?
Nov 9, 2009 at 2:29 AM
