2000 Buick Regal fuel pump
130,000 MILES • 6 CYL • FWD • AUTOMATIC
JOSTW24
locate and change fuel pump
Feb 17, 2010 at 12:35 AM
TOOOMANYTOYS
  • 513 POSTS
The fuel pump is located inside the fuel tank. This certain vehicle may have an access door allowing you to remove fuel pump from inside the trunk instead of removing the tank. open the trunk pull up carpet toward rear seat if there is a shiney metal panel held down by four bolts. You can remove fuel pump from inside. If no access panel is found it is necessary to drop fuel tank to replace the fuel pump.
Feb 17, 2010 at 12:41 AM
