2000 Buick Regal door lock
MYCAR353
Electrical problem
2000 Buick Regal 6 cyl Automatic 169000 miles
The right front door no longer locks. But I can still lock all the doors with the lock button.
Jun 9, 2008 at 5:39 AM
SERVICE WRITER
  • 9,123 POSTS
Probably a switch or actuator problem. This is the test for the switch:
https://images.2carpros.com/forum/automotive_pictures/30961_11lock_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_11locka_1.jpg
When you say the lock button operates the lock, do you mean the key FOB?
Jun 9, 2008 at 10:36 PM
MYCAR353
yes, the door button and the fob will lock all the doors except the right front. The key also does not lock the door.
Jun 10, 2008 at 11:58 AM
SERVICE WRITER
  • 9,123 POSTS
Okay, now I'm with you. Can you hear the actuator working on that door?
Either way you'll have to pull off the door panel and get a look inside. There may be linkage disconnected or a seized actuator is what I would expect you to find.
Jun 10, 2008 at 1:33 PM
MYCAR353
Yes, I can hear something.
Jun 10, 2008 at 2:09 PM
SERVICE WRITER
  • 9,123 POSTS
Then you need to pull the panel off and get a look at the linkages inside. Keep the window in the up position to allow access. This sounds like a mechanical isue where something has come loose or is binding.
Jun 10, 2008 at 9:39 PM
