2000 Buick Regal cooling sencor
155,000 MILES • 6 CYL • FWD • AUTOMATIC
ONEWICCANCHICK
where is it and what does it look like? that is the code that came up and will it turn off the check engine light after replaced
Jan 12, 2010 at 10:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
it is located on the top left side of engine, below the throttle body. once replaced you will need to delete the trouble codes with a diagnostic scanner.
Jan 13, 2010 at 4:20 AM
