2000 Buick Regal Air conditioning only works on passenger s
95,000 MILES • 6 CYL • FWD • AUTOMATIC
TETHERMANIA
My 2000 Buick Regals LS only blows cold air on the passenger side and hot air on the drivers side. But after a 30 or so minute drive the driver side air starts to get slightly colder but not as cold as the passenger side. Can anyone help me with this?
Aug 19, 2010 at 10:16 AM
WYSDYM
I have the EXACT same Car, Model, and Problem, Started Yesterday for no reason! 09-01-2010
Sep 2, 2010 at 11:03 AM
TETHERMANIA
I took my regal to the shop last week to have them look at it because i thought it was the compressor. they called and told me that it just needed freon.after i got the car it was working fine but now it has dropped 5+ degrees on the drivers side again. the only thing i can do know is get a blacklight and see if i have a leak.
Sep 2, 2010 at 1:49 PM
WYSDYM
I just found it weird that if you do a search on it via the web you find this is a VERY VERY common problem with our make/model/YEAR, etc. But the fact that it was working perfectly one day then not the next. I have actually charged the freon myself (via walmart can and meter) before on my old car several times, but it's a pain and kindof risky (if you get the pressure too high etc) Plus you have to have someone to turn it on, and off, and more. But it's like $40 as opposed to $150. I know the compressor is working just wished it was a vacuum tube or something on the vent door as opposed to an actual leak. Blah. If you find out for sure, come back so I know where to start. :) ~Kymber
Sep 2, 2010 at 2:32 PM
