2000 Buick Regal
91,956 MILES • 6 CYL • FWD • MANUAL
DIANNA ENGSTROM
I recently had my coolant system replaced, and now have problems with the air conditioning, which is not in the same area I am told. When I turn on the air conditioning it blow hot air on the driver side and cold on the passenger side, it has dual contols. I seem to even have heat when using just the vent, or when everything is turned off. could it be a damper stuck? and if so where is it located?
Oct 14, 2009 at 2:01 AM
DOCFIXIT
  • 18,828 POSTS
What was replaced in cooling system?
Oct 14, 2009 at 2:47 AM
DIANNA ENGSTROM
The auto repair people replaced the following:
Intake manifold (fuel injected) intake manifold set,thermostat gasket, 195f thermostat, wynns cooling system flush kit, cooling tube, removed and replaced the antifreeze, oil filter, engine oil, plus misc. shop supplies, this was all to correct the coolant leak, at a cost of $1063.03.
Oct 15, 2009 at 2:07 AM
DSAMSON613
I have a 2001 Regal that has the same problem (from time to time). I have noticed that this only occurs in very humid conditions. If I shut the car off, and restart, the problem usually goes away. For me, this happens so rarely, that I have not taken the car in to the shop. I suspect some sensor has some humidity and after the car warms up (even just for a short time), a restart makes the problem disappear.
Oct 16, 2009 at 5:11 AM
DOCFIXIT
  • 18,828 POSTS
Nothing done would effect A/C your system is self-diagnostic have AC checked for codes this will tell fault.
Oct 16, 2009 at 7:55 AM
