2000 Buick Regal
ROCKY_LE5
Electrical problem
2000 Buick Regal 6 cyl Two Wheel Drive 160000 miles
low beams and park switch work. when applying the flasher arm to apply the high beams, they won't stay on, it work if i hold the arm. Are the high beams supposed to stay on when bringing the arm toward me or is it suppose to just flicker on then off.
Oct 13, 2009 at 3:19 AM
  • 110,248 POSTS
They should. Can you push the switch forward? If not, then the switch needs replaced.
Nov 24, 2009 at 2:53 AM
