1999 Buick Regal transmission delay
98,000 MILES • 6 CYL • FWD • AUTOMATIC
BBCADDY
iI am having problems with my my transmission jerking with in gear changes.. almost as if the motor mounts were bad... i have had those replaced.. did not fix the problem... then a bad solenoid cade read in the diagnostic... had that replaced .. did not fix the problem. when the car is cool it runs great but after 10-15 mins when it gets hot it gets worse.. hesitating between gears...
Apr 4, 2010 at 2:11 PM
LEGITIMATE007
  • 5,121 POSTS
is there a check engine lighter on
Apr 6, 2010 at 8:14 AM
