1999 Buick Regal third brake light
1999 BUICK REGAL
125,000 MILES • 6 CYL • FWD • AUTOMATIC
VALLEYFOOTBALL89
third brake light is out, i have replaced the bulbs, no power at the bulbs but power at break switch? any suggestions?
Sep 22, 2010 at 5:20 AM
WRENCHTECH
  • 20,761 POSTS
The power for that light leaves the brake light switch and goes directly to the light so you have either a wire problem or one of the connectors isn't making good contact. It's a white wire.
Sep 22, 2010 at 5:57 AM
SATURNTECH9
  • 30,869 POSTS
How did you check for power with a test light or a multimeter?If you used a multimeter did you check for power across the power and ground terminal's of the third brake light connector?Or did you ground the black lead of the meter and just check for power to the light?
Sep 22, 2010 at 6:03 AM
