i have a 3.8 that has the factory supercharger. the car has a brand new exhaust( front -Back) water pump checked and is fine, coil pack seems ok, not blowing codes. will run but gets hot if you feather the peddle. says low collant but is not low, lots of smoke when you run it. runs like its on 4 cylinders????any thoughts?
Jun 21, 2008 at 2:41 PM
