1999 Buick Regal Replace fuel lines
80,300 MILES • 6 CYL • FWD • AUTOMATIC
WHISKEY
How do you replace fuel lines in this car
Mar 22, 2009 at 3:01 AM
  • 110,248 POSTS
Hi:
Basically, you remove the old and replace with new. I always purchase the steel fuel line in a spool of 25' and using a pipe bender, and try to match to the new to the old. Also, you will need to double flair the end with a new fittings. Make sure to double flair the ends to get a good tight seal.
May 3, 2009 at 11:00 AM
