1999 Buick Regal Power windows
11,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCHNELLE
The power windows work about 50% of the time.
Half the time they work, half the time they are stuck down or up.
I have replaced the control box in the drivers side door, no help.
Someone suggested it might be the PCM.
Help
Aug 28, 2009 at 12:47 AM
2CARPRO JACK
  • 11,533 POSTS
More likely the BCM (Body Control Module) If all 4 stop working,it could very well be the BCM shutting it down.Or it may even be the Master switch (drivers side). Find a shop with the proper scanner to watch what the BCM is doing and they can see if signal is getting out of the master switch to the BCM
Aug 28, 2009 at 1:03 AM
