1999 Buick Regal power locks not working
150,000 MILES • 6 CYL • FWD • AUTOMATIC
TOMO65041
none of the switches work the remote does not work the remote will flash the lights and honk the horn so that seams to be ok I can hear a clicking under the dash near the steering column when the switches are used I am asuming this is a relay
Jan 19, 2010 at 8:46 AM
SCOTTY DEE
  • 592 POSTS
Check power and ground at the master switch on the drivers side. If you have power to the switch and the lock are inoperative replace the master switch.
Jan 27, 2010 at 2:32 AM
