1999 Buick Regal Not cooling
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
JULIEAWEST
Hey guys,
The a/c will not cool on the drivers side, but cools on the passenger side.
Also, the gauge that tells you what the temperature is outside, is registering 54 degrees. It is actually about 100 degrees outside today.
I need help!!!!
May 19, 2008 at 10:51 AM
JOHNNY D
I am having the same problem with my 99 regal, after alot of research the only thing I have come up with is the blend door actuator. If you find anything else out let me know because I am having no luck with this problem.
May 27, 2008 at 2:39 PM
JOHNNY D
Just letting you know I had a diagnostic done on my ac and it turned out to only need freon. On a dual system car if the freon is low it can cause one side to cool and the other one not.
May 28, 2008 at 1:26 PM
