1999 Buick Regal Headlights
78,000 MILES • 6 CYL • FWD • AUTOMATIC
KENNYGEEE
My low beam headlights only work when I pull the hi/lo lever to change from high beam to low or vice versa. I have to hold the lever to keep them on. I have no high beam at all, only low no matter which position the lever is supposed to be in. The high beam inicator indicates high beam, but only lows come on when lever is pulled and held
I checked the bulbs with a continuity tester, they seem to be fine. I checked fuses, all seem good.
The headlights do not come on when dark as they should as there is a darkness sensor. They do not come on when the light switch is pulled out either.
Any thoughts would be greatly appreciated,
Kenny G
Jul 15, 2008 at 12:46 AM
DIESAL01
had the same problem it was the headlight switch, like 50 bucks, good luck
Jul 20, 2008 at 10:34 PM
