1999 Buick Regal fuel pumps
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRED58
is then a fuel cut off switch or a reset button for this model we are going to replace the fuel pump just need to know if there is a special proceeder t do this thanks
Jun 3, 2010 at 3:03 AM
INTERNETMECHANIC
  • 700 POSTS
No reset. If you have good voltage and ground at the proper terminals for the fuel pump motor connector, and no pump action, then suspect the pump.
Jun 3, 2010 at 3:17 AM
