1999 Buick Regal fuel pump problem
RONDEB
1999 Buick Regal
car starts up and runs fine for the day but tried to started again after work and it wont start, the engine do turn over when I turn the key. It seems like no fuel
going through. I had the fuel relay replace and the fuel resister re-routed because of heat and it worked fine for that day but the next day it didn't start up. I do suspect
it's the fuel pump. question is how do I change the fuel pump? I need a step by step instructions to replace it.
Please help.
Mar 13, 2010 at 8:00 PM
  • 110,251 POSTS
Before replacing it, have you checked fuel pump pressure when it doesn't start? I would recommend making sure it is bad before you replace it. It isn't a fun job.
Here is a how to for checking:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Mar 16, 2010 at 12:13 AM
EDENYSJR
The problem has been resolved. It was the "new" fuel pump, defective. Ordered another car started right up.
Aug 11, 2023 at 9:23 AM
  • 55,851 POSTS
JACOBANDNICKOLAS is one of our best! Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Aug 12, 2023 at 2:17 AM
