1999 Buick Regal coolant leak
170,000 MILES • 6 CYL • FWD • AUTOMATIC
JANYCE LEE
I've owned this car for 4 years and have had minimal problems and have kept up with routine matinence. I recently noticed a coolant leak coming out near the belt side of the intake manifold, by the black plastic pipe leading to the belt tensioner. Is this a common problem? What would be required to fix this?
Oct 19, 2008 at 5:04 PM
BMRFIXIT
  • 19,053 POSTS
Very common failure is the intake and its gasket coolant pressure test is recommended to check for leaks need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
https://images.2carpros.com/forum/automotive_pictures/99387_Untitled_2.jpg
Oct 19, 2008 at 10:39 PM
