1999 Buick Regal Car Starting up?
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
TDOT101
  • 9 POSTS
I have a 1999 Buick Regal LS with a 3800 engine 130k on it. My car won't start.....I can turn the key n its cranks up but it wont catch it though. I had new spark plugs and wire put on about a week ago! And then the vechical started up n i drove it for about three days..once i was driving everything in my car shut dwn electrical and as well as the engine! i started back up and it came back on..A couple of days later it stop on me I was told that i need a new alternator so i went and grab a rebuild one but my car still won't start Plz let me know any possible problems asap I really don't know whats wrong plz HELP!!!!!
Oct 13, 2010 at 3:25 AM
WRENCHTECH
  • 20,760 POSTS
Is the starter cranking the engine normally?
Oct 13, 2010 at 3:31 AM
JDL
  • 16,098 POSTS
If it cranks good but won't start, have a helper crank it, while visually check for spark at the plugs. You can use a known good spark plug or spark tester. Where applicable, pull a plug wire stick tester in boot, ground metal part of tester to metal part of engine. Engine cranking watch for spark. If you have spark everywhere, use a gage and check fuel pressure. Can you check for applicable codes? Also, where applicable, your security system could cause an issue? Battery has a full charge and all connections are good?
