1999 Buick Regal brakes not releasing
1999 BUICK REGAL
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
VAUSTIN
after replacing the rotors and pads on the front, the brakes don't seem to be releasing. What could possibly be causing this?
Jun 27, 2008 at 7:41 AM
DOCFIXIT
  • 18,828 POSTS
When calipers get old the rubber seals do not keep out water & crud. So when you push the piston back you carry that junk into the caliper. After you apply brakes the piston will not retract. There is a square cut sealing ring that is streached on application and is what pulls piston back . Thats why on cars with years & milage I would always put calipers in the est. Been bit to many times
Get you couple rebuilt calipers and you will be ready to go.
Hope this has helped
Jun 27, 2008 at 7:55 AM
