1999 Buick Regal Battery Cable
45,678 MILES • 6 CYL • 2WD • AUTOMATIC
JILL M. SHARPE
On yesterday I was told my battery cable was corroded. At this time I am not experiencing any starting problems. Is this something that I should be concerner about immediately?
May 15, 2008 at 12:52 AM
MIKE H R
  • 3,094 POSTS
Yes, when a battery cable gets correded it could cause starting problem. You can use like in the old days coke a cola and pour it on the terminals the acid in the soda nutralizes the corrosion on the cables. or take the cables off and clean them with a brush or wire brush to get good contact.
May 15, 2008 at 3:24 AM
